Does anyone know how the hell you remove an ECU from its impenetrable position?
Results 1 to 10 of 10
Thread: Does anyone know how the hell you remove an ECU from its impenetrable position?
    Sep 2009
    76
    Default Does anyone know how the hell you remove an ECU from its impenetrable position?
    I thought getting a new ECU and keys from the States was the hard part, in reality, winkling the old ECU out of its impossibly inaccessible position strikes me as ...well....impossible. Any suggestions anyone?
    Thanks
    Doug
    Apr 2017
    6
    Quote Originally Posted by totaldoug View Post
    Thanks
    Doug
    lift the tank and hold it up with a 2x4 block, Getting it unplugged is tuff. Get you wifes small hands in there. Thats what I did.
    Jun 2016
    50
    I took out the battery too. Then you can unbolt it.
    Jun 2016
    50
    Ya that will work tooo. Lol
    Sep 2009
    76
    Default Removing an ECU
    Thanks buddy, it never occurred to me to pull the ECU in its box backwards from under the tank rather than try to get it out forwards....A little expertise can take you a long way, I might finally get my IB beauty running again without having to be ripped off by the local dealer!
    Cheers
    Doug
    Quote Originally Posted by BC Rune View Post
    Jun 2016
    50
    Since its all apart use some Dielectric*grease on the connections when you reassemble.
    Sep 2009
    76
    Annoyingly, having managed to get the old ECU out and a new one plugged in, I can't get the damn thing to pair with my new key....lights come on but no-one's home in the fuel pump department! Whether I need to pair it with two keys or whether there's a fault in the new ECU is anyone's guess..... Just when I thought I was winning!
    Jun 2016
    50
    The first time I tried it didn't work. Just go through the sets in the manual again you probably missed a step.
    Sep 2009
    76
    As you might guess,i am no further forward and also not regular at checking this site! To which steps are you referring in the manual? I can't find a procedure for pairing keys to new ECU's.
    Thanks
    Sep 2009
    76
    Ah, think i just found it on page 21-6....thanks bud.
    Doug
