Clutch Leakage Problem
Results 1 to 4 of 4
Thread: Clutch Leakage Problem
    Mar 2019
    Bueno Aires Argentina
    20
    Default Clutch Leakage Problem
    Good evening, I am with a loss of the hydraulic in the clutch pump (below near the oil filter) at the junction of the piston cover. I guess it's the piston piston retainer that drives the rod. Someone has the catch code (I can't find it in Partzilla). I appreciate advice on how to assemble / disassemble the clutch cylinder. From already thank you very much. Daniel
    Let's Geaux Ra Rune's Avatar
    Oct 2009
    DFW-Texas.............. ...It's a whole other country.
    930
    The parts you are looking for are on the Rune Illustrated Parts Breakdown page titled: Front Cover / Transmission Cover...
    Item #6 is the entire Clutch Slave Cylinder Assembly Part Number 22860-MEC-010 priced at $78.08
    Item #7 is only the Slave Cylinder Part Number 22861-MEC-000 priced at $47.65
    This info is from the Partzilla Honda Rune webpage catalog...
    'Ra Rune'
    *(It's OK to talk to yourself... it's even OK to answer yourself... but, if you ever catch yourself saying, "Huh??? What??? Que???")
    Frequent Poster (>1000 posts) Afghanpilot's Avatar
    Nov 2007
    Birmingham, AL. No more Afghanistan!! Yeaa!!!!
    1,230
    Quote Originally Posted by RUNE517 View Post
    Your Rune sure seems to have a sh!! load of problems! What's the back story on your Rune? You buy a Rune that needed to be fixed up, prior owner never took care of it or someone sell you a lemon?
    All good questions. Wasn’t there a guy on here who was racing his Rune? Hope this isn’t the one.
    -Ollie
    I'd much rather be on the ground wishing I was in the air than being in the air wishing I was on the ground.
    2004' CBC #585
    Lucky 7 Radial Bike- www.jrlcycles.com
    https://www.combatvet.us
    Mar 2019
    20
    Thank you very much for the past information. Very grateful to Runa Ra.
    From Rune517, his comments surely speak of the person who writes them. Daniel
