Forward and rear bars
Results 1 to 13 of 13
Thread: Forward and rear bars
    May 2020
    12
    Default Forward and rear bars
    I’m looking at remotely buying a 2004 rune and I know there is a way you can tell from the Vin number if it was delivered with the forward mounted or rear mounted handlebars.
    Here’s the VIN - 1HFSC53064A001104
    Can someone help me decipher that?
    Jun 2009
    Reston, VA
    238
    Default Bars
    I don't know the code and while mine came with forward bars, I changed them to rear bars. As I remember there is a forum here for bars and you may want to read through the forum.
    May 2020
    12
    What’s the process to change the bars? Are you just changing or re-mounting the existing bars or do you have to get new ones?
    6,833
    Mine was "delivered" (a "thousand years ago ) with forward bars. But within months, I changed them out to rear bars. So the VIN might not be any indication of what is on it NOW................
    6,833
    Quote Originally Posted by WiscoGary View Post
    changing out the bars.....different part number. And while some claim you could stretch the brake cable, I changed my brake cable out as I recall. Again, that was so long ago....it's hard to remember. Like late 2003?
    6,833
    From the Tech Forum....right up top....the thread with EVERYTHING you wanted to know about forward bars, rear or pull back bars, A bars, B bars, how to, etc. And brake hose replacement IS recommended.........
    https://www.runeriders.com/forum/sho...-bars-question
    May 2020
    12
    Thanks RedValk, great information. I was able to determine the bike I’m looking at has the forward bars for sure. I definitely want the rear bars, I’m about 5’-9” and don’t want that forward sitting position. My 57-year-old back probably wouldn’t like it much.
    I wonder if the “B” bars are even still available?
    6,833
    I'm just under 6 foot, and I found the forward bars doable.....but not quite as comfortable as the rear bars. I'm thinking for you, rear bars are definitely the way to go. Bars still available. $246.62 on Partzilla and $189.61 with Southern Honda Powersports....just doing a quick google check.
    May 2020
    12
    Thanks again RedValk, much appreciated. This forum is totally invaluable if you’re buying or own one of these bikes and you guys do such a great job moderating and maintaining it.
    I’m leaning towards looking for a 2005 model because of the bar situation, also I like the chrome wheels and I understand there was a change to the front forks that helps with the “squeaking“ problem.
    Looking for a black, low mileage and mostly stock, or can be returned to stock version.
    Frequent Poster (>1000 posts) Falcon Wing's Avatar
    Aug 2005
    Falcon Colorado
    1,075
    01 IR Wing
    04 CBC Rune
    May 2020
    12
    I'm looking for a '05, but searchtempest is a cool tool. Thanks.
  14. #12
    Member RUNE517's Avatar
    May 2007
    19
    Default is a 2005
    If you can live with a color other than a Black one?
    price is good, says needs to sell
    What little is wrong (paint) is easily fixed, and the chromed plastic part can be replaced, along with that part is one to watch out for, it can get caught on a pant leg when backing up your Rune and snapped easy enough.
    ~~~WHEN YOU'RE FINISHED CHANGING---YOU'RE FINISHED~~~
    -Benjamin Franklin-
    ~13~
  15. #13
    May 2020
    12
    Yes, I’m actually talking to the owner of this bike. Small Rune world I guess!
