Avon Update - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 46 of 46
Thread: Avon Update
  1. #41
    Member MO Rune Rider's Avatar
    Join Date
    Aug 2007
    Posts
    972
    Default
    Quote Originally Posted by RaRune View Post
    Jim,
    Why didn't you use the 150/60 R18 67H TL BT090 Battleax..?
    It is the exact size of the stock Dunlop D251 except it's rated H speed instead of V speed.
    I wonder if those 150/60's were even available back when I first switched to the 140/70 BT45'S? But like the information you found, I probably wouldn't have gone with an H rated tire anyway, even if they were available at the time. The only issue I've ever encountered with my 140/70 BT's is that they require 42psi (cold) to last very long, let them get low and they tend to begin cupping fairly quickly.
  2. Remove Advertisements
    RuneRiders.com
    Advertisements
  3. #42
    Let's Geaux RaRune's Avatar
    Join Date
    Oct 2009
    Location
    DFW-Texas.............. ...It's a whole other country.
    Posts
    951
    Default
    Quote Originally Posted by MO Rune Rider View Post
    What is the entire model number of your front tire...? Just wondering.
    'Ra Rune'
    *(It's OK to talk to yourself... it's even OK to answer yourself... but, if you ever catch yourself saying, "Huh??? What??? Que???")
  4. #43
    Join Date
    Aug 2007
    Posts
    972
    Default
    I'm not at home right now to put eyes on the tire, but I'd guess it's the exact same bt45 140/70 18, v rated radial, currently listed all over Ebay, which is where I order a lot of my tires.
    MPN: 072818
  5. Remove Advertisements
    RuneRiders.com
    Advertisements
  6. #44
    Join Date
    Oct 2009
    Location
    Posts
    951
    Default
    MPN: 072818
    MPN: 072818 - That is what I was trying to ascertain... That is a bias ply tire... It probably doesn't matter in your case because you are a darksider anyway...
    Of course, if your rear CT is a bias ply tire, it's a NO Biggie... and you're Good-To-Go! That is at least your technology matches, front to rear... LOL
    'Ra Rune'
  7. #45
    Join Date
    Aug 2007
    Posts
    972
    Default
    I think it's a bias ply tire. Now I'm certain to die a flaming death from BOTH my tire choices. CT on the rear and mis-matching bias with radials. Oh my! I guess I've been lucky this past 40,000 miles or so. Of course, now with 'rona' loose around every corner, nook and cranny, what's the big deal if I die a flaming tire choice death? They could write it down as just another 'rona' death and no one would be the wiser.
  8. #46
    Member
    Join Date
    Jul 2020
    Posts
    10
    Default
    What About DUNLOP D251 tire, I think it is the better choice.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
