1 - 9 of 9 Posts
Still looking for technical advise!
Here is the delema, does a GW ECM would allow the Rune engine to properly operate knowing the folling differences between the 2 engines :
GW: as 2/ 40mm throttle bodies units
Rune: Six individual 32mm throttle bodies feed the cylinders
From the Honda online part I was able to find out the throttle body diagrams, but I can't find the Rune throttle diagrams.
From the Rune diagrams, I can see couple of sensors, such as SENSOR SET MAP and REGULATOR ASSY PRESSURE...
WOuld that have any effect on the Rune engine /ECM when installed on the RUNE ?
http://www.hondaonlineparts.com/showVie ... L1800|2004
Any help would extremely appreciated
GREAT !! at least now I can start to understant the engines differences.
Since I am not a Honda specialist, I am not really sure what I can make out of it, but I will be able to pass the info to my French Honda dealer willing to help me on this project.
Many Thx
Hi Jaques,
j should have an italian process not for spacelab but working.
a) reduce the size of the gasoline tube (in one point inserting a narrow diameter hole.
the torque will not much be reduced but the maximum power yes.
b) if necessary you may also reduce the surface of the air filter covering with some tape.
j think it could be the best work for limited period.
hannibal
p.s. meeting for plate confirmed just now. should be the right time??? :oops:
Asking a French hill Billy mecanic,, I was told that 6 cylinders were far too many anyway ! I should go ahead and disconnect one or 2 cylinders...and that should do the trick !
Disconnect one or two cyclinders! :shock:
I'm a Kentucky hillbilly mechanic and I highly advise against that action!
You could cause serious engine damage!
Surely that is a plaisanterie! :lol:
Yes , that just a desperate jock before finding a real educated proposal...
By the way, I spent almost 18 months in Louisville kenctuky when I was a student back in 1975.
I loved it, I guess they loved me aswell back then, since I am , Honorary, distinguished Louisville citizen ( Mayor A. Sloan at the time) ! Latter on I became Captain of the Belle of Louisville !!!
So when youall talk HillBillies & *******, I really get it !!
1 - 9 of 9 Posts
