well between valk & rune,nothing the same,like u posted........
between the wing and the rune very diff.....computer system all diff....
the cams and the valve train specs are diff..also.the exhaust ports specs.are diff....
so that means the heads are diff....also.
but the pistons and connecting rods are the same specs.....
i have found out that there are two diff.... pistons used,same specs.
the oiling system alittle diff......the intake and the injector mapping system are diff..... there are even diff....in cal. runes in the cam specs....
the cal.. rune is detuned i beleive i little more than rest......
......................................... tom / gone
