1 - 2 of 2 Posts
Hi!
Looking for a lift stand, that fits the Valkyrie Rune motor and allows for easy movement of the bike around the garage.
Any tips are appreciated! :)
Thanks,
Robin
I would try to see if RaRune would make and sale his version!!! See below post from an earlier one by RaRune...
I currently have/use a pepsx stand and yellow adapter. But would prefer RaRune's setup if he had made and sold them before I got my current setup. I'd even learn to live with the white color. OK, the hell I would, I'd paint it a different color....;) Click on image links, if they don't show up in post...
RaRune said:
This is my design stand and heavily modified yellow adapter... The mods are - NO bolts, adapter was welded together, angle iron brackets to allow the bolting of the two trapezoid shapes which are made of 1.5 x 1.5 x .187"wall steel tubing, NO yellow paint... the white color is double powder coated on all surfaces, and .250" steel plates for caster stops and caster mounting.
First incarnation:
View attachment 15506 View attachment 15514 View attachment 15522
Second incarnation: With this stand, you couldn't even push your Rune over from the front, back or side... It's as stable as a battleship on land...!
View attachment 15530 View attachment 15538
I made three adapters and two of these stands... one set for me and another for 'Baiao'... and one adapter to leave at my friends M/C shop for when I need tires or any other Rune lifting need.
1 - 2 of 2 Posts
