oh GOODY....you've hit one of my areas of REAL expertise :lol: They call me Trailer Queen....have trailer, will travel. I trailer one of my two Runes about once every other month....to somewhere....some rally.
Here is the scoop:
When they come from the factory, they are tied down to the case savers...and to a point under the seat. For mine, i had to attach higher than the case savers to get some leverage, so i attach at two points. One, i use soft ties to attach to the fork area right around the turn signal. This gives a really solid tie point. In addtion, for added stability, i use a "Canyon Dancer" ...which goes on the bars and provides another point of attachment. However, i do NOT crank down much on this attachment to the bars...and i don't recommend putting much pressure on a handle bar. you could actually bend your bar if you did!
For the rear, i had to see a Rune in the crate from the factory to figure this out. Remove the seat, then there are two black plates that attach to the frame with a single phillips screw. Remove the screw, remove the black plates on each side, and carefully 'snake' a soft tie under the exposed frame. You will probably need needle nose pliers to get the soft tie out form inside the frame. temporarily store the black plates for transport. To attach the STOCK seat, there is a place in the seat frame where the factory deliberately built a split in the frame of the seat for the strap to fit thru for trailering. If you have a Corbin seat, you don't have to 'worry' about this.
let me know if this all makes sense. I can elaborate if need be. In addition, i have soft material wrapped around my straps on the rear...to make sure they don't rub against the side of the bike and scuff it any. I should take some photos of all this some day. My next "Trailer Queen" adventure will probably be the Hoot, late June. The next one after that, InZane Valk/Rune rally late July.
Hope this helps....let me know if you need more details.
