Hi all
I Installed my Ultimate bolt caps ( Boy, do they improve the appearance of the Rune ) and I had a lil' difficulty installing the ones on the inside of the fork tubes next to the fender, marked as CAP " J ". SO I am passing along an easier method. Pop off the 4 caps ( with a very small screw driver ) off the allen head bolts holding the fender on. Then loosen the rear bolts and then remove the foward bolts . Now you will be able to "tilt the front of the fender up and easily install the caps on the nut head.
Hope this helps !!
Rich K. ( Rune Ski )
Hope this helps !!
