Dan,
Looks GOOD. I installed kurykayn red spider lights. Rear fender, 2 each side (facing down,I had to make brackets that attach under the fender) 1 light under each of the Rune Ski side covers. I made a bracket to attach to the engine that the light attaches to.This way the light shines out and and towards the inside of the side cover,looks cool with the light coming out of the louvers. I also polished the "inside" of the side cover so the light reflects a bit more. From there I went foward and attached 2 each side under the long chrome side covers, between the gas tank and the engine valve covers(facing down ). I then attached 2 under the steering neck and above the radiator cowling . I only have 12 installed so far.
Dan,how did you route the wires so they would not be seen to wire the lights under the front fender? Did you run them with the brake lines?
Thanks,
Rich k ( Rune Ski )
Go to it John ( Skibum)
