"Correct key blank is based off of LETTER on the two
original keys that came with the Rune. IF keys are all lost
you are screwed and need a new ECM and the correct keys. The same as if
you had a bad/faulty ecm. You can also use
the full key code stamped into the bottom of the fuel cap to find the LETTER
you need to order the correct blanks. You must have one of the two original keys registered
to the ECM in the first place to start the process to add additional keys, for up to a total of 4,
and use the special tool to do so. No original keys, you're not adding shit.
The below comes from the link after it, refer to the two # 5: the AXX/BXX or CXX/DXX
is based on the code on the two original keys, like say D35. The D being the letter needed,
the XX just stand for whatever numbers are on the key. That same D35 or DXX is the last
part of full key code on bottom of fuel cap.
KEY, BLANK (NO.1) (KEY NO. AXX/BXX)
KEY, BLANK (NO.2) (KEY NO. CXX/DXX)
Honda Motorcycle 2004 OEM Parts Diagram for SIDE COVER | Partzilla.com
It's your Rune, do what you want.
Do a search, lost keys (all of them lost) has happened before!"
"Edit:
Below from a 30 second search:
Input from Al/Asacuta.....I miss that individual and talking with him.
~~~"You can't program ANY keys unless you have at least one key that is already programmed into the ECM.
You can't start with all new keys unless it's a new ECM. Loose all your keys,
and a new ECM is in your future. Keep one key in a very safe place.
If you need 2 keys day to day, store one of your originals and buy another.
New keys have an RF chip in them that communicates with the ECM to exchange encrypted data. "~~~
Exchange data is the reason old keys become useless with a new ECM, they tag each other, or pair to one another.
No old original key that was paired to ecm, you need a new ecm.
You all have a Great Day!
(spent to damn much time in Texas, I'll spell it my way-Thank You...
"Ride Safe and Ride Often"
