Guest
·I've had my bike since nov. '04 and no problems.
The Starter turns,I get plenty of fuel ,no Fire!
I tried the Flooded engine fix, no luck...
I checked fuses and connections,battery,etc. no luck...
Any suggestions ?
Thanks !!!
HiRev
Doesn't hurt to check the switch....Thanks!TaraRune said:Uh.................Kickstand?
Thank You....RUNE102 said:Sounds stupid, kill switch in run? I had a friend, ran the battery dead then saw the kill switch was off.
Pull a plug and see if you have spark when you turn it over.
The only other thing I can think of is if the bike got tipped over enough and some how the bank switch is engaged. Thats a oil filled switch that shuts off the bike if it falls over. It self centers once its back up.
Try the other key. Maybe its reading the first key correctly. Shot in the dark.
do you hear the fuel pump pressurize when you turn the key?
John DK,John DK said:HiRev,
If any of the advices above dosen't do the trick, and you still don't have the plug sparking, you must have an electrical problem other than fuses not working, and you must call the dealer (again).
For JerseyIllusion and Runerod I'll just mention that here in Denmark it´s considered a certain kind of impolite patronizing communication behavior to adress a present person in third person, like "he" ... :wink:
Point taken anyway, JerseyIllusion![]()
Will Do...Thanks!John DK said:HiRev,
As Hannibal wrote : Let's hear from You when the solution to your NSAA-problem has been found (NSAA : no smoke at all)
Hopefully,I'll get an answer by Friday,to Post!hannibal said:hi,
please do not forget to post the solution
hannibal
