Hi All, my mechanic guru took these pics,some of you might remember that I had a slight coolant leak that ran down by where you stick the key in. Well since then the guru has solved the issue,however I had not just 1 leak but four. I posted pics in my gallery these are pics that the guru took showing all the places where we did in fact have leaks,3 of which I had know idea. As I said all are fixed now just needed tightening up.But could have been a major problem later. Note the fuel tank needed to be lifted & radiator shroud removed & alternator removed in order to get to all the location where there was a issue. I highly reccomend that when you have your bike serviced by Honda that you have them check the cooling system for leaks,you will be glad you did. Just thought I would pass this along.
Brent
Brent
