Update on Dunlop tire D251. My dealer stated he should have the front tire on June 27th. The rear tire arrived.
We'll see. I'll let you know.
Fingers crossed. I also have a front and rear OEM on order. Haven't heard anything......think I'll ping my Dealer today............... Hmmm......June 27th. That would be an excellent birthday "present" if mine came in then. Yes, that's my birthday..............Update on Dunlop tire D251. My dealer stated he should have the front tire on June 27th. The rear tire arrived.
What site? Was a price listed? ThanksWhile shopping online I ran across a site that stated "Tire won't ship until Mid June".
Don't remember, I searched everything that showed up in Google. When I saw June I just passed it by. But you can order from where I bought. I believe they ship. If the don't I can pick it up for you and ship it. I bought at Broward Motorsports in Fort Lauderdale, ask for Gabriel M tell him my name Mitchell Pine. He should be able to help. Let me know if you need my help.What site? Was a price listed? Thanks
Here's the site I was looking at with a ship date. https://www.summitracing.com/parts/dmp-302550"Thanks for the offer, I'm good. Was looking for price to see if it's in line with what some say they will cost."![]()
"Thanks!Here's the site I was looking at with a ship date. https://www.summitracing.com/parts/dmp-302550
Was trying to follow all the different steps and speculation through this thread. What was the actual root cause? Part 46400-MEC-016 was one of the parts / actions you took, or this part was THE root cause? Just looking to understand in unambiguous terms, what exactly caused the lock-up (other than old / bad brake fluid) and needed to be replaced. Thanks. And thanks for posting the issue so fewer of us have to experience the ""Oh, [email protected]#$%^&*!!!"I have an update on the seizing of the front brake. I replaced the valve assembly for the front brake. See attached part. Drained all brake fluid front and back since both systems are attached. I have a higher rear brake pedal now and a whole new feeling with the front brake handle. It seems that front handle travels smoother and brakes have 30% more sensitivity. This brake system is clean.
Thank You http://www.speedbleeder.com/ !!!
Plus: Speedbleeder(s)!"![]()
"Where did you find a PCV(Part 46400-MEC-016)? All the sites I look @ shows either out of stock or unavailable.See attached part.
The root cause was contaminated brake fluid which created a buildup and sludge like substance in the reservoir/valve and brake lines. It got to a point that the brake fluid was only flowing towards the caliper and due to the build up in the lines and valve system at the brake handle the fluid backed up creating pressure in the caliper where the brake pads remained on the rotor and overheated causing the the front brake seizure. Immediate remedy is to let it cool down 100% that will give you me 20 minutes depending how much you use the front brake. I decided to tow. I replaced the part described in this thread. That did the trick. Remember your rear brake is tied into your front brake so when you replace the brake fluid do front and back.Was trying to follow all the different steps and speculation through this thread. What was the actual root cause? Part 46400-MEC-016 was one of the parts / actions you took, or this part was THE root cause? Just looking to understand in unambiguous terms, what exactly caused the lock-up (other than old / bad brake fluid) and needed to be replaced. Thanks. And thanks for posting the issue so fewer of us have to experience the ""Oh, [email protected]#$%^&*!!!"
